not spinning
Hellow,
I have frigidare front loading washer that will not spin. The door locks, light says locked. The dispenser drawer is closed, if opened the lock light goes out and the door unlocks.
Is the problem the door lock switch or the motor controller? drum will not turn was or spin.
I was looking for a wire diagram so i could trouble shoot the door switch/lock probelm, you can’t read the wire diagram!
Thanks for the help
Remove the bottom access panel and look for an envelope with the tech sheets. Perform the troubleshooting as described in the tech sheets.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=336506&&model_id=117980
Nonething Works On Door Panel ; Check Wires Were They Bend At The Door Are Broken For Sure Also Did Get A Few Drips Of Water Out Of Water Line Looks Like Inside Th Door Were The Tube Goes Up And In To The Door Push The Tube Up Soom And Quick Leaking For Now; Guess I Better Stop Before I Know,how And What To Do If I Replace Tube In Door If I Need To Wires I’am Sure I Can Fix Will Just Remove The Hole Door So I Can Work On It Just Not Sure About The Tube I Call Appliance Company They Did Not What To Try And Repair These Please Help.
