off button not operating
my off button does not turn the oven off…I had to use timers and quite by luck it turned it off…eventually unplugged it. Could you tell me if this is a problem with Kitchen Aid…what part it could be…is it expensive…or what should I do?
my kitchenaid oven model KERA205PSS2 "off" button does not work…is this a kitchenaid problem…is it expensive to fix and what part is required:mad:
Here are the parts
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=KERA205PSS2
Cannot say what part is to blame.
Could be the Membrane switch (keypad) (Item 2 in Section 2) re. the key switch is bad.
Or it could be the control board itself (Item 12 in Section 2)
Perhaps try the following first.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
