I have a Kenmore range that shows only 8’s on the ERC display. I cut the power for a couple of minutes, no change. I’m guessing the ERC, it is just a guess. Thanks Bruce
Good guess. Whether it’s hard to read the display or some of the digits are not showing, the board (ERC) is the problem. Could you double check the model number? 911.30469292 does not come up, it’s probably a digit off. Post the model number here and I’ll send you a direct link to the new board.
Would I be correct in assuming the oven sensor is also the thermal coupling, the line that runs from the broiler up into the oven with the little rounded tip?
