Only Freezer works
Only the freezer portion of my Maytag MFD2560HEB is working. Anyone know what the problem may be?
Hello…If your freezer is working normally, and there are no issues with the compressor and compressor fan, then I would suspect that the damper control is not working properly. This part opens and closes, in your refrigerator, to allow freezer cold air to cool the refrigerator side. I hope this helps you out. VB
