I have a Maytag over the range microwave. A while ago it stopped heating food. EVERYTHING else works. I thought it was the magnetron or diode but did a bit of troubleshooting.
The microwave works fine as long as the vent fan is on. If the fan is off then the microwave wont heat. Everything else works like the display, timer, light, platter etc. But turn the fan on and it starts working again. I would have thought the fan portion is an entirely separate thing because it’s purpose is to vent air for the stove below it. The microwave should work (and did used towork) without the need for the vent fan.
Any ideas??
