only the top works clock is displayed time can not be reset no other pads will work o
Range top control panel displays time only cannot adjust time no pads work on control panel
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MES5752BAB
Try unplugging the unit for a couple minutes to see if it will reset.
If this does nothing then odds are that the control board is toast.
