When I turn on the oven or broiler to pre-heat them, the panel lights up and stays on for one minute then shuts off. The elements do not even start to warm up. Could the transformer be burn out?
By "panel" are you referring to the electronic control??
If so, I don’t know anything that would cause a set control function to just go away as if it was never set besides a problem in the electronic control itself.
The only separate transformer on your range looks to be for the florescent light.
JMO
Dan O.
http://www.appliance411.com/parts/?ref411=GE+Range*The Appliance Information Site*
=D~~~~~~
I can’t think of anything else that could cause it. A problem anywhere else in the appliance should not stop the control from doing what it was programmed to do. The control should continue on until the end of what it was set to do.
BTW. That part looks to have been discontinued and is no longer available. If needed you’d have to try to find a company that could repair the original.
JMO
Dan O.
=D~~~~~~
