Oven and Broiler does not work
The Oven and the Broiler do not work. No clicking sounds or gas hiss. After entering the desired temp setting, the display simply returns back to the normal off setting of 100 degrees but with no sounds.
I recommend that you contact http://www.advovenrepairsf.com/ they are able to fix your damage! Good luck!
