Oven does not work, neither Broiler nor Bake, timer & control panel appear to work, top burners work fine.
I set the oven for a 3 hour self clean, using Maytag directions, no trouble doing so before this, nor this time, but…now the small red oven light indicator does not go on, nor does the oven work-heat, either for "Bake" or "Broil". There is no error code that shows up on the controls.
(Have not tried "Timed Bake", never use it, but DID try Clean cycle again, as per instructions, for a 30 min. cleaning…timer and lock appear to work fine, and shut off fine, but no heat. )
I can see…from what I have read in present forum listings, that apparently it is better not to use the self-cleaning cycle at all…true?)
(If it’s a thermal fuse switchout, where is the fuse located? Don’t see it on any of the four exploding charts for this model…I can check for continuity if I can find it…)
Any ideas gratefully received.
