Initial problem oven would not light even though the igniter was working, prior to that it worked fine with a good blue flame. I replaced the safety valve and igniter.
The oven would then light but burns with a high yellow flame. I then replaced the regulator and burn tube. Still the same problem.
I suspect a faulty safety valve ??
