Oven cutting off then back on
Oven will completely shut off (all power) after around 20 minutes of usage, whether on Bake or Broil. It will completely off (all power, even clock) for about 60 -90 after which it will come back on again.
Not sure if it is microcomputer or control panel membrane. Any thoughts. I am told the micro computer is not longer available from Whirlpool and no substitutes. I was shocked to hear that…not that old.
Any ideas?
marty
Most likely the problem is a bad control board (microcomputer) which comes together with a suppressor board and installation instructions for this board. I do not know who told you this part is no longer available. It is available and you can buy it from Appliance Parts Pros.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=121975&&model_id=264481
