Oven doesn't heat to temperature
When the oven is set to 450 degrees, it heats to 300 degrees. I have replaced the temperature sensor on the inside of the oven. The bottom element glows red when it is heating and the oven turns it off when it thinks it has reached temperature. I’m not sure what could be wrong.
The bottom oven (which has mechanical controls instead of digital) is working within 25 degrees of specification.
