Oven doesn't work
Hi - does anyone know which part needs to be replaced when the oven doesn’t work? Is it the gas valve or the ignitor or what?? I’m stumped :confused: Much thanks!
It could be the igniter (Yours has a spark igniter), the valve, a wiring problem, the spark module, or the control. What happens when you try to turn it on? does it click?
— Begin quote from oilslinger53;178434
The broiler clicks twice and then does absolutely nothing- no sounds from the baking mode either.
