Oven door lock keeps running.
The oven door lock keeps running. Cycling from open to close and open again and again. The manual says it is either the clock / oven control or an open wire from the lower latch switch. I am in the process of pulling oven out of the wall to check the lower latch switch wire. Any additonal thoughts or areas to check are appreciated.
