My tenant used the self cleaning feature of the oven and now it is stuck in the locked position and the oven door will not open. The lever will slide a little to the right if it is put back on the clean cycle; but it will only slide to the left a very small amount. I tried turning off the power and also doing the clean cycle again, but the door remained locked. Any advice/suggestions will be appreciated.
I have same problem with Whirlpool oven- error codes F5 and E1. How do I replace the door latch if door is locked?
