While replacing my oven’s igniter, I bent the hinge or hinges on the oven door. I have watched every video I can find and none show the type of hinge I have. I want to remove the oven door, any ideas? It is a Kenmore 790.75761001 and works great except for the problem I just caused! Thanks.
Hi.
To remove the door just open it half way and holding on both sides pull it out.
To replace the hinge remove two screws holding it to the frame, drop it down slowly and then take it out through the opening.
The hinges are not identical.
316007002 left side
316007001 right side
Thank you.
Simon.
