My oven door will not close! It is about 4" from closing so I replaced the hinges and it didn’t make a difference, can anyone give me an idea as to why my door will not shut!
Hi.
First of all check the positioning of the hinges on the frame.
Check if the hinge plates are not bent(parts in which the hinges inserts.)
Check if the door latch is not in the way.
Thank you. Post the results.
Simon.
