I had the heating element rupture and short in the upper oven. I ordered the replacement heating element and installed it. After an hour with the oven on, the oven temp only reaches 225 degrees when set to 450 degrees. Is the new heating element bad or is there something else that I should check?
Related topics
Oven still not reaching temp after replacing sensor and element | 1 | 133 | November 25, 2019 | |
oven bake element wont heat up | 1 | 1376 | November 2, 2010 | |
Thermador SCD302T very slow to reach temperature | 1 | 93 | September 12, 2022 | |
Oven not reaching proper operating temperature | 1 | 1117 | February 27, 2014 | |
Thermador won't heat | 1 | 788 | February 22, 2014 |
