Oven heats to 100 degrees only. Broiler and top burners work fine.
[FONT=&quot]I have a GE Profile Range model JGBP79WEV1WW.
Everything works, except the oven. It only shows a temperature of about 100 degrees. What part do I need? What is the part number? What is the cost?
Thanks a million.
Casseopia:D
[/FONT]
Remove the oven floor and the flame spreader. Remove the bottom drawer. Check the Bake igniter for continuity. Post the results.
Here are the break down diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=20730225&&model_id=214137
