Hi,
I’m trying to find the correct part number for the oven igniter on an old Capri branded propane stove.
Model#970-560511
Serial#5F001208
Hi,
Model#970-560511
Serial#5F001208
Your model number isn’t coming up anywhere.
Do you have a picture of the part?
Well, I finally pulled the dead igniter out and found that it was a Norton 501A. I replaced it and the oven works fine.
However I don’t believe that was the original igniter as it appears to have been installed with plain old plastic wire connectors. Any thoughts?
Just out of curiosity I may call Sears and see if they have a part number.
It’s weird that I can’t find any hits for the model number…
Yeah, couldn’t find it anywhere.
Just use ceramic wire nuts and it should be fine.
