Oven will not turn on and igniter is glowing red. Would like to replace it to see if that fixes the problem. Serial number is 1X808094442. Need help identifying the replacement part.
The model number you posted does not come up. Verify and repost it please.
One of the most common flat igniters used in Magic Chef ovens [part]12400035[/part]
It has numbers of different connectors what make this igniter really universal.
You can check if the igniter is the cause of the problem by measuring the current drawn by the igniter. If the reading is 3.2 amps or less - the igniter has to be replaced.
