Oven ignitor removal
Does wall oven have to be removed from wall to disconnect ignitor wires or is there an easier way
Some times, you can pull the connector through to disconnect, without removing the oven; but if it disconnects while you’re pulling it through, the only way to finish the job is to pull the oven out of the hole. Always turn it off at the breaker, before your repair, regardless of the ease of the job.
