I just replaced the ignitor in the oven and it worked, but the oven got to about 500 degrees and would not shut off. Could I have shorted the gas valve?
Hi, Leesa.
Most likely it’s not a gas valve. To provide you with more assistance we need the complete model number of the unit.
Simon.
— Begin quote from Simon / APP Team;812771
Hi, Leesa.
Simon.
The model number is JGBT32GEL2WH
Hi, Leesa.
Simon.
Thermostat? Wired wrong?
— Begin quote from LeesaBennett;812779
Sorry that model # is JGBP32GEL2WH
You need to check if the ignitor wires insulation is not damaged and bare wires not touching the cabinet. Then check the ignitor connector plug. If you have a multimeter then check the oven sensor resistance. At room temperature you should have about 1100 ohms. If all of this checks OK, then most likely it’s a defective control board. It looks like this part is no longer available.
Simon.
