Oven Temperature Probe
I’ve read the FAQ’s about my part number 316233900 being replaced by part number 316233903 for my oven model number 790.71513405. The replacement part’s harness connection is different and does not fit. In the FAQ’s video it says to use a set of wire connectors to cutoff the ends and crimp the wires together. In the written response to a past customer with a different oven model, it says to use ceramic wire nuts. What does all of this mean and there are no compatible wire nuts for my oven model? How do you do any of this? There is no video for this operation. :confused:
