Oven turns off
Hi; my Amana ACS 3350AS has had a slightly temperamental touchpad ever since I’ve had it (for about 7 years). Now, when I turn the oven on, it will occasionally, after heating up, turn itself offcompletely, ie even the clock will reset itself. After some time (presumably after it has time to cool down), the clock will come back on displaying 1234 or 12 something). Today, however, it appeared to work fine (but I am obviously wondering whether or not it will act up during the holidays!)
Please help!
Thanks!!
Most likely the problem is a bad control board. Unfortunately this part has been discontinued by the manufacturer and is no longer available.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=23854
Thanks, Gene. Is there something cheap I could try before I end up buying a new oven? Like a thermostat or something?
Thanks!
No, there is nothing else left.
You can try PCBR.BIZ. Maybe they can fix the old control board.
