Oven will not heat or broil
Our oven will not heat or broil. The top still works fine and the oven light and clock is working fine. I checked the elements and there does not seem to be any obvious damage to them. I checked the breakers for the house and did not see any that where tripped. When you turn on the oven everything acts like it is working properly, just no heat. I did look at some other post and they stated to look at the tech sheet, of course there is a place for the tech sheet, but no tech sheet to be found. Any help would be appreciated.
