oven will not heat up
oven does not heat up at any temperture. there is power. the front control panel light is out. so i can’t tell the setting. i was thinking of ordering a new clock control panel,which show the temperture setting and see if that works.hope to hear from the forum soon .having company over next week!
Did it click when you touched any pads?
Did you check the circuit breakers?
I need you to answer on these questions before we go further.
