When I try to turn the oven on or "set the temperature" then press "Bake" to turn the oven on, the digital readout immediately rises to the desired temperature (it thinks the oven is already heated to temp) but no heating occurs.
Broil works but no "baking".
I replaced the thermostat but that did not help.
Next step in my mind would be to replace the lower element but being a "digital" oven, I think the problem could be in the oven’s electronics…
By "thermostat" I am assuming you replaced the oven sensor (Item 5 in Section 4).
Since the unit thinks it is already at operating temperature it will not heat so I doubt it is the element.
At the top of my list would be the control board (Item 7 in Section 2)
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
250 ain’t cheap but if you had a tech do it your bill would probably end up close to 500 with parts and labor. Then a new stove starts to look pretty good.
