Oven will not light
Broiler and stovetop work fine
Suggestions?
The most common problem would be the ignitor using a clamp on amp meter to one lead of the ignitor it should draw 3.2-3.6 amps if not replace it. if it doesn’t glow at all its bad if it glows some it may not be pulling enough amps to open the valve
