Self clean worked fine. Later when turning on oven, no heat. Broiler no heat also. Circuit breaker not tripped. Any ideas will be appreciated. Betsy.
Your model number is missing several digits at the end of it.
Many of theses units have a thermal fuse/ cut off mounted to the back outside of the oven wall.
This is probably blown.
Thank you. It must be a thermal fuse.
— Begin quote from denman;809865
