Hi folks. I have an oven that won’t heat on bake, broil or self clean. It also won’t lock the latch for self clean, instead the display will blink while attempting to lock the latch. The error code is E1-F5. Following the tech sheet, I replaced the latch. Still have the same problem, and the new code was E6-F2. So I replaced the control–and I still have no heat on bake, broil or self clean, although the latch now locks on self clean. Any ideas?
Thanks so much
Brad
Whirlpool RBS305PDQ10:confused:
Hi Gene, turns out that if I push the door closed as far as possible everything works fine. There’s no obstruction in the door area and the seal looks good. The oven light goes out with the door closed, but the door doesn’t quite close far enough to allow it to lock for auto clean. So looks like maybe the hinges are bent, but I can live with it for now as long as it cooks.
I really appreciate your feedback and everyone who may have helped.
