range top burners are ok, broiler will lite & works fine.
however, when choosing the bake setting the following happens;
ignighter will glow and temp increases very s-l-o-w-l-y with a moderate smell of gas. No flames from burner. Temp change from 75 to 110 degrees takes 15-20 minutes.
Most likely the problem with your oven is a bad igniter.
Let me explain how it works:
The igniter is wired in series with the burner valve. When the thermostat calls for heat, line voltage is applied to the circuit. As the igniter begins to glow, the current increases. The current flow causes the valve to open when the igniter becomes bright red (almost white). Flat igniters operate from 3.2 to 3.6 amps. In your case the current is less then 3.2 amps and even it does glow it does not open the gas valve.
Replacing the igniter should solve the problem.
My dryer has a burning smell. Nothing is on the elements. They seem to heat too hot. It would burn your hand to touch the back, inside top, of the dryer. Even when you turn the dryer to delicate it is very hot.
