One day, after baking for about an hour, the oven won’t turn off. Push the off button and get a normal beep, but the heat element continues.
Cut off the power to the oven via the circuit breaker. Upon re-powering the oven, the heating element commences to heating but the control panel does not show the oven as being in bake mode.
The control panel display indicates PF for power failure. If I push OFF button, the PF clears, the control panel still doesn’t show the oven as baking, but the heating element continues to cook.
So, I removed the control panel (after killing the power). Does anybody know if this sounds like it is a problem with the control panel, the board behind it, or maybe something else?
Thanks for any ideas.
RickG
