oven wont stay lit
Wirlpool SF368LEPTO
[LEFT][COLOR=#000000]I have had the same problem as others. The oven ignitor comes on, clicks, ignites, but keeps on clicking then all goes off. I tried replacing the ignitor. After installing it is still doing the same thing, the ignitor clicked, burner came on, ignitor continued to click, and it all shut down…What do I do next??? I spoke to a tech who said that it might be just a loose screw on the front of the oven burner, and that the stove was picking up that there is a bad ground. That did not work,
I have been told to try replacing the spark module. dose that sound right?
and if that dose not work that it is likely the main control pannel? any ideas
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/308482-oven-wont-stay-lit.html#ixzz2CQG55csk
http://forum.appliancepartspros.com [/COLOR][/LEFT]
I have the same problem with a different model, replace the ignite with the burner (bake) and still does the same, Please we need help, thanks
