Oven won't turn off- even with new control board
I just replaced the control board for my whirlpool double oven mod# RBD305PDB12 when I switched the breaker on a "PF" was on the screen, I was able to hit all the buttons except the off buttons (they didn’t beep when puse) - so I realigned the ribbon cable. The second time I switched the breaker on all the buttons worked but the oven wouldn’t turn off (the off button made the sound of working) and continued to get hot.
The reason we bought the new control board is because the oven wouldn’t turn off and would get so hot that it would lock the oven. What could be the problem if it’s not the control board?
Btw, the clock still doesn’t work either, I’m able to set the clock but it turns off (again, same issue we had with the old control board…
Thanks!
