I have a Spectra XL44 oven model number J6BP28BEA6WH. The broiler and the stove top work fine, but the oven suddenly stopped working. I’m wondering if it is the ignitor and if it is why does it work for the broiler and not the oven?
Fritz Miller
Fritz Miller
teeeeoff said:
I have a Spectra XL44 oven model number J6BP28BEA6WH. The broiler and the stove top work fine, but the oven suddenly stopped working. I’m wondering if it is the ignitor and if it is why does it work for the broiler and not the oven?Fritz Miller
The reason it is, is because there are two ignitors. One for bake, and one for broil. The part # is WB2X9154 If you take the bottom floor of the oven off, it will lead you to the bake ignitor. That is usually the problem. Tom http://www.applianceeducator.com/parts.htm
