My washer is over filling ,not to the piont it over flows but more water than it normaly would use on a load. It used to fill just over the load now it fills to the top of the tub almost. I have replace the water sensor
AP3206676 (WH12X10247) - Sensor with no results . the water valves will shut off if i unplug the washer. Thanks Bill
