I came home today and found water all over the floor from under my refridgerator. It turned out that the consensate drip pan was full and overflowing with water.
I couldn’t find any leaks in the water lines but there was a lot of debris all over the coils under the unit. I cleaned this off with a vacuum and cleaned out the pan. The fan beside the pan runs. Unit has been in service 65 months without prior problems.
Is there a heater that boils off condensate when defrosting. Could the blocked coils have contributed to this?
BTW: I don’t use the water tap and it has been on RED to change the filter for years
This is a KitchenAid KSRS25ILBT13 side by side…
Many Thanks
Bob in Riverside, CA
