I need to connect the new overload switch, which is slightly different from the original. Does the 1 wire go through the brass post hole and if so does it need covered by electrical tape?
What is the part number of the new overload and ptcr device
— Begin quote from richappy;769096
WR08X10026
That is a klixon overload device, it gets pushed in the compressor common terminal and one of the fridg power wires gets pluged in the spade terminal.
