HELP!! I have a WFW9200SQ00 and it’s DEAD! Nothing comes on except the lock button. When the power button is pressed, I hear three chimes.
I bought a control electic board (8183261), replaced it and still the same.
Try running it thru diagnositc first, see if you get any error codes.
[FONT=Swiss721BT-Roman][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1][LEFT]Execute this procedure with an empty drum. All of the steps
below must be done in sequence in order to reach the
Diagnostic test. This executes the automatic test only.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1][LEFT]1. [/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Close the door.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1][LEFT]2. [/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Push power.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1][LEFT]3. [/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Select the “Drain and Spin” program.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1][LEFT]4. [/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Deselect the rinse option (for Kenmore only).[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1][LEFT]5. [/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Select “No spin”.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1][LEFT]6. [/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Push “Prewash” option four times within five seconds. If
Prewash is not present on this model, press “Extra Rinse”
option four times within five seconds.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1][LEFT]7. [/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]The automated test program is started (not possible to
skip steps).[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1]8. [/SIZE][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]To cancel the test program press the “Stop” button.[/SIZE][/SIZE][/FONT]
[SIZE=1][FONT=Swiss721BT-Roman][SIZE=1][/SIZE][/SIZE][/FONT]
[SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Post your results[/SIZE][/SIZE][/FONT]
[FONT=Swiss721BT-Roman][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Nat
Yes. Switch the breaker as well. is it true that electronics has 2yrs warrantee?
Thanks for all your posting. Do you know the part number for the cpu board on the left side of the machine?
Behind the control panel?
yes. it’s a combo board in a "T" shape. You’ll see it when you open the top panel. From the front, it’s on the right side. Sorry, I’d said left earlier.
That is the main microcomputer, machine control part number AP3968028, $218.51, from this site.
Nat
I did some more checking and the power supply to the motor controller board is causing the problem. When I unplug it, all the lights come on.
Can you gives me the part number to the motor controller boards at the bottom of the machine?
tomlao said:
HELP!! I have a WFW9200SQ00 and it’s DEAD! Nothing comes on except the lock button. When the power button is pressed, I hear three chimes.I bought a control electic board (8183261), replaced it and still the same.
i have the exact same problem. tech came over friday(2/13) and said it was the MCC. 150.00 for the service call and 570.00 for the part.the washer is going to be 2years old on 3/29,so whirlpool is paying for the
part. i see that the same part can be bought here for 236. a nice markup, eh
I received the drum roller assembles and am trying to disassemble the dryer to replace them. I am having difficulties in determining the best procedure and only taking it down as far as I need in order to replace those rollers. Any help will be appreciated.
Lift the top, Remove the front, remove the drum.
— Begin quote from libertyappl;31287
[LEFT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Execute this procedure with an empty drum. All of the steps[/SIZE][/SIZE][/FONT]
[SIZE=1][SIZE=1][FONT=Swiss721BT-Roman]below must be done in sequence in order to reach the[/SIZE][/FONT][/SIZE][SIZE=1][FONT=Swiss721BT-Roman]
[SIZE=1]Diagnostic test. This executes the automatic test only.[/SIZE][/LEFT]
[/FONT][/SIZE][SIZE=1][FONT=Swiss721BT-Black][SIZE=1]1. [/SIZE]
[LEFT][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Close the door.[/SIZE][/SIZE][/FONT][/LEFT]
[LEFT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1]2. [/SIZE][/SIZE][/FONT][/LEFT]
[LEFT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Push power.[/SIZE][/SIZE][/FONT][/LEFT]
[LEFT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1]3. [/SIZE][/SIZE][/FONT][/LEFT]
[LEFT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Select the “Drain and Spin” program.[/SIZE][/SIZE][/FONT][/LEFT]
[LEFT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1]4. [/SIZE][/SIZE][/FONT][/LEFT]
[LEFT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Deselect the rinse option (for Kenmore only).[/SIZE][/SIZE][/FONT][/LEFT]
[LEFT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1]5. [/SIZE][/SIZE][/FONT][/LEFT]
[LEFT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Select “No spin”.[/SIZE][/SIZE][/FONT][/LEFT]
[LEFT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1]6. [/SIZE][/SIZE][/FONT][/LEFT]
[LEFT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Push “Prewash” option four times within five seconds. If[/SIZE][/SIZE][/FONT][/LEFT]
[LEFT][SIZE=1][SIZE=1][FONT=Swiss721BT-Roman]Prewash is not present on this model, press “Extra Rinse”[/SIZE]
[SIZE=1]option four times within five seconds.[/SIZE]
[LEFT][/LEFT]
[/LEFT]
[/FONT][/SIZE][LEFT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1]7. [/SIZE][/SIZE][/FONT]
[/LEFT]
[LEFT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]The automated test program is started (not possible to[/SIZE][/SIZE][/FONT][/LEFT]
[LEFT][SIZE=1][SIZE=1][FONT=Swiss721BT-Roman]skip steps).[/SIZE]
[/FONT][/SIZE][SIZE=1][FONT=Swiss721BT-Black][SIZE=1]8. [/SIZE][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]To cancel the test program press the “Stop” button.[/SIZE][/SIZE][/FONT][/LEFT]
[LEFT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Post your results[/SIZE][/SIZE][/FONT]
[SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Nat[/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1][/LEFT]
[/SIZE][/FONT]
[LEFT]Sorry if this is too old of a thread but I ran the diagnostic program on my machine. The display started with a C:01 and ended with an F20 with the 20 flashing. Can you please tell me what this error code is? Thanks[/LEFT]
[SIZE=1]below must be done in sequence in order to reach the[/SIZE]
[/SIZE][/FONT][FONT=Swiss721BT-Black][SIZE=1][FONT=Swiss721BT-Black][SIZE=1]1.
[/SIZE][/FONT][/SIZE][/FONT][LEFT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Close the door.[/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1]
[LEFT][/SIZE][/FONT][FONT=Swiss721BT-Black][SIZE=1][FONT=Swiss721BT-Black][SIZE=1]2. [/LEFT]
[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][LEFT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Push power.[/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1]
[LEFT][/SIZE][/FONT][FONT=Swiss721BT-Black][SIZE=1][FONT=Swiss721BT-Black][SIZE=1]3. [/LEFT]
[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][LEFT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Select the “Drain and Spin” program.[/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1]
[LEFT][/SIZE][/FONT][FONT=Swiss721BT-Black][SIZE=1][FONT=Swiss721BT-Black][SIZE=1]4. [/LEFT]
[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][LEFT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Deselect the rinse option (for Kenmore only).[/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1]
[LEFT][/SIZE][/FONT][FONT=Swiss721BT-Black][SIZE=1][FONT=Swiss721BT-Black][SIZE=1]5. [/LEFT]
[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][LEFT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Select “No spin”.[/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1]
[LEFT][/SIZE][/FONT][FONT=Swiss721BT-Black][SIZE=1][FONT=Swiss721BT-Black][SIZE=1]6. [/LEFT]
[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][LEFT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Push “Prewash” option four times within five seconds. If[/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1]
[LEFT][SIZE=1]Prewash is not present on this model, press “Extra Rinse”[/SIZE]
[/SIZE][/FONT][FONT=Swiss721BT-Black][SIZE=1][FONT=Swiss721BT-Black][SIZE=1]7. [/LEFT]
[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][LEFT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]The automated test program is started (not possible to[/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1]
[LEFT][SIZE=1]skip steps).[/SIZE][/LEFT]
[/SIZE][/FONT]
Sorry, I guess I’m unable to enable the automatic test program. I see what the C:10 and F20 codes are which doesn’t surprise me because it’s sitting in my garage.
[/LEFT]
