Pilot flame like in a gas dryer
I have a Frigidaire glgq2152es gas dryer that looks like it has a pilot like flame coming out from the gas valve assembly even if it has finished the drying cycle or when it is in pause. The only way to turn it absolutely off is by shutting down the main gas valve (between the gas tank and the appliance).The machine starts, the igniter has a good glow, it has a good flame and it heats properly the clothes. Is it the gas valve assembly - part number 5303207409 - which is damaged because it doesn’t close the gas flow? We recently changed both gas valve solenoids part number 5303931775 and it has the same kind of pilot like flame on. Thanks a lot.
