Oven may or may not heat. This is intermittent. No fault codes are displayed. When it does heat, temp rises no higher than 200 deg. Will not warm on self clean either but door locks properly. Timer and display read normal. I cut power completely to try reset, but still won’t operate. Could it be anything else but the control unit? I can do a simple plug-in replacement, but parts sites say that wiring may be different than the original control… Please help.
Related topics
GE Oven Malfunctioning | 2 | 1233 | July 7, 2010 | |
GE Built-In electric oven | 1 | 390 | April 12, 2017 | |
GE Wall Double Oven Top Oven Not Heating | 0 | 2992 | January 11, 2008 | |
GE Range Oven will not get hot | 2 | 1435 | October 1, 2010 | |
GE Oven doesn't heat after using self clean | 5 | 4309 | February 4, 2011 |
