Please Help - Whirlpool WFG524SLAS
Hello all,
I’ve been having this problem for quite some time and it’s literally driving me crazy. My oven burners and broil work with no problem but when I use Bake, it will ignite (sometimes first try but not all the time) then when it hits the set temp, it will fail to re-ignite. I hear 3 clicks and the sound and smell of gas but it will not re-ignite, sometimes if I’m lucky, it will. I also see a spark on the igniter as well. First I replaced the Spark Control module and this did not fix the issue. I then replaced the bake igniter, still no luck. Could it be that I have a bad gas valve even though I hear and smell gas when it tries to ignite? Another thing that I’ve done was drill additional holes on the bake burner which also didn’t work. I’m stumped… please help!
