Poor Drying/Heater Element Good
Dryer works poorly in both timed dry and automatic
Observed Heating element with front panel removed. Heated up to cherry red, then cycled off. After delay (long?) came back on.
Tried without any vent hose connected to remove any possible vent issues. Still poor perfromance. There are three thermostats
One heating element enclosure, two on exhaust vent after the blower. Any ideas?
Between the L1 & neutral shoud be about 120V and the same with L2 & neutral between L1 & L2 should be 240V a 10% varience is allowed.
If you remove each set of wires off the thermostats you should be testing for continuity, If one of those doesn’t have continuity then that’s the bad one.
By looking at the thermostats I do think that this unit has the incorrect parts installed on it. If needed I can give you the part numbers.
Nat
