power problem
Started with problems with the fan running continuously after microwave cycle completed. Pointed me to the switches. Thought I’d be smart and clean the small cavity where the door hooks lead to the switch. Did not unplug it(stupid I know) and moisture got into the switch and I heard a loud pop and all went dark. Checked the 2 fuses, 1 was bad 1 was ok. Changed the bad one out and checked all 3 switches for continuity and inside each switch to see if anything was broken. All 3 look brand new & making good contact. Now with new fuse I only get the exhaust fan and the microwave cavity light but no panel action at all. Also the fan is slower and the light is dimmer. I felt like the pop noise came from the back left of the machine. I don’t think I mixed up the switches, but anything is possible. Any help greatly appreciated.
