Hi… I have a problem with my dishwasher !!! When my wash is finish… my drain pump start for out the water in the dishwater !!!
But … my drain pump work around 5 minutes when all water is out !!! and the drain pump make a wrong sound… because don’t have water in the pump !!!
I bought a new pump… !!! and I have always this problem !!!
What’s stop the drain pump… !! Is it a timer, electronic switch, float valve …???
Sorry for my english… I speak french !! And thanks youi for your help !!!
— Begin quote from alexandre1733;290797
Alexandre,
As best I can tell, there was a noise in the drain pump, you replaced the pump and the noise is still there ?
And you have had the noise from the pump, since you’ve had the machine ?
The component that controls the drain pump, is the electronic control board,
[part]AP3775964[/part]
Is your complaint, the pump does not turn off ?
[part]AP3133590[/part]
You may want to check and make sure the unit is installed properly.
especially the drain hose routing and possible electrical conduit shorted to the drain pump wires/terminals.
