Pulley is grinding on the bottom of cabinet
I have a GE WPRE6100G0WT Washer, and it seems to have a problem when running where the tub or pulley is grinding against the bottom of the cabinet. It makes a very audible grinding sound that can be heard throughout the whole house, if there is a part that can resolve this issue can anyone identify the name of it.
You need to take off the front panel and watch it while it is operating. The problem should make itself known. To take off the front panel insert a screw driver carefully in the gap between the top and front near the edges and you will release clips that hold it on.
