No lights, can’t start washer, but pump keeps going until unplugged
Sounds like a control board problem so try changing it out. For some reason it is not listed as being available on this site, and I suggest you buy from this site because you can return it if it does not fix the problem, something very few other parts companies allow. So I suggest you call APP and see what the problem is with respect to the part.
