I replaced the bearings, belt and wax motor. my problem now is when it gets to the drain and spin 1 the timer seems to stop it also shows 124.9 volts to the pump, but there is no pump action, if you manually spin the dial around and if it catches the pump will run and it will spin, it next goes through the next fill and tumble cycle, but when it gets to the first drain and spin2 it again stops and you manually have to spin the dial again and when it catches it will continue to the second drain and spin2 and from there on it will work properly.
I will be grateful for any help as satated before when it goes into the drain and spin1 and drain and spin2 it reads 124.9 volts in the pump but it’s not operating
Read more: http://forum.appliancepartspros.com/washer-repair/535487-timer-pump.html#ixzz2fGFqQYWG
