"F" and "DL" signals
The unit was shutting down and giving "F" and "DL" codes. Repair guy ($100.00) determined the MCU to be bad (a $300.00ish plus repair).
Had nothing to lose so I unplugged most lines to the Motor Contol Unit (MCU) sprayed with WD-40, let dry, and re-connected. Maybe a temporary patch but the washer has been working great for a month:)
Great, glad you got it working. The wiring between the MCU and and Door Lock and the CCU should always be checked and tested before doing anything else when you get the error messages like that, so good job.
Thanks for the info.
